Anyone know what caused the symmetrical banding in the lines of the sky? I had done several earlier versions with no banding. The sky was too muddy so in his last one I went into the JPG file and cleaned up between the lines. (TOOK FOREVER with a two nib brush! )
The file rendered fine with no sign of the lines.
Setting: 1000/100 convert to dot @ 195 LPI (I’m guessing around 11:30 to 1200 am 01/21/19. (It was the last one engraved if that helps.) If it matters, each engraving was run twice; one for scoring for coloring and then a final run.
For comparison, this was an earlier version. I had not cleaned up the lines in the sky yet so it was a different JPG and I’m pretty sure it was vary power SD setting.
Some kind of funky interaction between the LPI of the engraving vs the DPI of the image? I’m pretty sure this kind of thing has happened to me on regular toner-based laser prints when using screens to print the image. Seems like changing the dpi a little bit to an odd number was what was needed to fix it. A desktop publishing expert is who we need here.
Yeah I think this is a moire’ pattern affect between the spacing of the lines in the image and the LPI setting. If you look close (and maybe cross your eyes) you can see a pattern in the original artwork too before cleaning up the muddy areas.
You could try changing the LPI setting or maybe simply rotating the image in the GFUI might take care of it (or might just change it to a different pattern.
Convert to dot gives you a pattern. Usually not a noticeable one, but every now and then the planets align just wrong… (I tried to use convert to dot and wide spacing to make sieves and faux halftone out of uniform greys, and nothing doing. Always some complicated pattern.)
