I did end up getting the cloud s6 fan and the ventworks 6" window vent which was a bit pricey but just wanted to make it as clean as possible. I do have a huge coffee table for it directly in front of the window I just need to raise it a few inches to make it level with the window vent and I will be able to make the exhaust all straight line for optimal efficiency.
The vent does not need to be straight, especially with an external fan.
You would be better served making sure the machine is on a flat, stable surface - assuming the table you have is just that.
Sounds perfect. I bet the effort you put into your setup will pay off for you. I know I’m glad I put in the effort for mine.
The coffee is super solid and will be perfectly leveled so I should be all set with that I know any bends in the exhaust system will decrease air flow efficiency so I am really hoping to keep it completely straight but we will see once I start setting everything up.
Thanks! Glad to hear yours worked out well. I figure if I’m going to do it I might as well go all out! Just want it done right the first time so I don’t have to mess with it later.
