This evening I cut some of the spikey bits for my knitting machine. My first run came out just as expected. I pulled that sheet and the cut pieces out, put in a new sheet of acrylic, made sure it looked ok on the screen, pressed the flashy button, then set about peeling the masking off of the first batch.
Then I heard a Thunk, which was the print head running into the lower right corner. I pressed the button to stop it, turned it off, and pulled the plug (which I always do anyway). That was at about 10:45 pm 3/14/21. Since it is really past my bedtime I didn’t do any further messing about.
So, why is the second one misaligned? I think I have printed one job after another before, but I am not positive that I have. Should you always go back to the dashboard before each print?
Thanks for your help.
This is what the Glowforge interface on my PC showed
This is what was printing
