Just got my glowforge haveing fun makeing earring. Jw what the best wood is to use ?
Every type of wood will have positives and negatives. Tear drops tend to be tiny at the top which makes hardwoods more likely to break there - while plywoods will have the grain going both ways so less likely to break. If you’re engraving into them then hardwoods are wood all the way through - while plywoods have draftboard in the center.
There are so many variables depending on your specific design and what you’re planning on doing with it!
evansd2
February 27, 2020, 6:52pm
Discussed many times! Dig around, there are more than this.
Hi y’all! There’s so much info to sort through in the forums and I’m very new to the community, so I apologize if this is a redundant topic.
When I purchased my GF, it came with several sample materials. I’ve been getting on a wood earring kick, and really like how the walnut hardwood looks for dangling earrings. However, GF is sold out of the walnut and a couple other hardwoods that I was interesting in buying (not sure how long that will be?). That being said, and being so new, I’m hesitant t…
https://community.glowforge.com/search?q=wood%20earrings
I made these with the proof grade walnut hardwood.
Instead of getting sleep after a hard week at work I was messing around in Inkscape trying to understand how to design stuff.
Late night and 4ish hours later (which is part of the reason I said no to the design a day challenge)…
[image] [image] [image]
And just because I found one of my really old creations from years ago in the box in the background… I give you… (warning: not made on a GF)
[image]
system
Closed
March 30, 2020, 9:11pm
5
