Correct. At least according to Dan - although I believe there is a bit of tube magic too as he said it’s a different tube as well.
You can make a tube with more power in similar form factors - there’s a relationship between the length, diameter and internal construct of the tube windings that all come into play. That’s why a Reci tube for instance will usually have more power than a similarly sized generic tube. However, you’re not going to more than double the power of any CO2 tube in anything near the same form factor or length.
That’s how a traditional laser cutter machine design often handles it - there’s an extension off the side for the added length of the longer tube but it’s usually covered with a metal box.
Our problem is it’s got to ride the rails with the head and since it’s not stationery the whole side of the machine as to be opened
