Whimsical bird on a leaf
I would think settings would be hard to pin down because of the danger of fire and the variability of the material. If I were to try, would start fast and very low power and sneak up on the proper settings.
Very valid point, just figured it would give me a starting point
I may try myself. I was thinking since it’s cold, dreary, and damp outside (where I live) anyway. I would try with leaves that are not completely crumbly dry and maybe a little damp.
Can’t discuss settings in this forum, but mine wouldn’t do you much good as my leaf was not completely dried out.
Sorry, I don’t know how to use this damn glowforge place yet :woman_facepalming:t3: mine are all wet outside too been raining alllllll day
There is a place on the forum to discuss setting. It’s the “Beyond the Manual” category. You would just start a new thread there, but I don’t think it would help in this case.
I’m not really super proud of this, just thought it was interesting. I have some better ideas in the works - just need nature to do its thing.
It would be neat to press a leaf and dry it, do the engrave then dampen the leaf again and mold it into some cool shape for display
Well, this was flat when I engraved it (I had pressed it), but then I let it revert back to its natural shape - so a shadowbox was appropriate vs. below acrylic or glass.
I have ideas for flat leaves that would need to be mounted. Have some lovely maples waiting to give up their foliage…
A flat sheet of paper, a pressed leaf (with engraving), and nose tissue. Then dampened with UV resin and when it looked right uv or leave in the sun, The resin should soak into everything , the tissue should have a few wrinkles but be mostly transparent, and when set will likely last longer than you will know about it.
What is nose tissue? Like Kleenex?
yup
Wow and double wow - never would have thought to use a leaf!
Is this a real leaf or did you make the whole thing with glowforge?
It’s a real leaf, from my yard.
What were the settings if you don’t mind me asking?
How did I miss this incredible creation?
Try them before they are dry. I’ve done green and yellow aspen, as well as oak when they are fresh. After engraving, put them in a press.
