Will this image work?
I often have such issues especially when I have used the trace function. It really is not so hard to wander down a line in node mode and just grab everything between two nodes you want to keep and just hit delete. As @evansd2 noted you don’t want lines 0.0003 apart anyway so a bit of deleting and moving the occasional node can clean it right up…
If there are 50 nodes between two points less than 1/16 of an inch apart it really does not matter what is going on as it will never show up anyway. If it scales really huge then you might remove fewer nodes but if you set the scale you are going to use and then which nodes need removal will be easy to see.
