So recently one of my GF was not clearing the smoke as well as normal, I cleaned the exhaust fan and grille again and again. Then I looked at the external fan!!!
And no, the banana was not in the fan!
Which model fan do you have?
It is a one of these:
In the UK I couldn’t get the fan that everyone in the US uses - is it the S6?
I think the main cause of the buildup is from damp - I don’t have blast gate - and it makes the residues very sticky. Had to quite chisel at this to get it off.
I could sell that to pot heads, they would smoke that stuff!!
Possibly moisture as mentioned. A dryer exhaust flap system will work to mitigate that. I measured the flow and the one piece flap model I have did not make any noticeable difference (stymies most bugs also).
What you are doing is another large part. I noticed a lot of cleaning was required when I was into the heavy 3D print rabbit hole (every 8+ deep engraves).
That resin residue glues the unburnt wood debris and really piles up fast.
