I needed to cut some repeatable width boards with my Track Saw. I whipped up this little gauge. Glue the small two blocks together for a beefier base, then push a bolt through them in to the slot on the larger piece. Wing nut on top…and bam! Simple tool. Hopefully it works for someone else besides me.
NOTE: Run the letters and lines as a SCORE, not engrave. I messed that part up. (still learning)
I want to love this, I can’t imagine it in action, could you take a picture of it in action? I don’t really understand how this is used. Thank you for posting your design! That is awesome.
haha… tools that justify each other are the perfect tools, #amiright?
Honestly - I put off getting a track saw because hey, I have a table saw, circular saw, band saw, jig saw… and didn’t think it’d be worth it. Breaking down material is one thing, but the way the Festool (the one I chose to go with) cuts without tear out, super smooth motion, easy depth…I wish I’d have bought it years ago. It’s an investment for sure, but I love it so far.
Love practical cuts. This is great! I made some glides for my table sled out of thick acrylic and they worked pretty good. I love when you can use the GF for tools.
oh… dang, I never thought that. You could make custom width ones and be perfect! brilliant. I am totally doing that this weekend. So…a rectangle is a good shape? ;). (way better than those circle slides)
I had to play around with mine. My sled was a little out of square. But it works. And if it gets screwed up. Just print another one. I rounded the ends a little so no sharp corners.
If you have a shop check out Dan’s other great shop videos.
I don’t think you actually need the setting guide though. Just set one guide from the other, as he shows doing with the setting guide, and they will be the same.
