I have a new WiFi network (new carrier). How do I change my glowforgeto the the network ?
First, make sure that your router is broadcasting 2.4gHz as the Glowforge cannot operate on 5 G. Hold down the print button on your Glowforge until is turns teal and then follow the setup instructions as you did when you first got your machine. Select | Glowforge
We also have a great support page in our Help and Learning Center for Wi-Fi connections and troubleshooting if needed:
Wi-Fi Network Connections and Troubleshooting
Hopefully, you’ve been able to complete the setup with your new network, but I wanted to make sure you’re aware of the resources for added help.
