Window
Hello,
I am printing with glowforge pro. If I am running my vent out the window do I turn the filter switch on or off for the glowforge? Thanks for any help!!
The option should be off if you are not using an external exhaust fan to pull the fumes from the GF.
The “air filter is attached” toggle can be read as “an external fan is attached”.
You turn it off if you want the internal exhaust fan to push smoke out of the machine.
You turn it on if you have an external fan pulling smoke out of the machine.
This topic was automatically closed after 29 days. New replies are no longer allowed.
