We are having so much fun with our Pro! I can’t believe it is here and what we have been able to make and learn so far. No tech issues and is working like a charm.
As I was doing a quick wipe down of the inside after creating a rubber stamp, I noticed the crumb tray seems to flex down in the back right corner. I pulled the whole tray out, made sure nothing was in the groves the feet sit in, and replaced the tray. Sure enough, the back right corner flexes (i.e. does not touch the floor of the GF when seated “normally”). It is difficult to say how much spacing is underneath, but I would guess it can be pushed down at about 1/8"-1/4" (but no more than 1/4").
The other corners all seem to sit correctly and touch the base of the unit.
It has not impacted any performance so far because we have been making small projects in the center of the GF.
So, my question is, does anyone else have this problem and should we be worried?
What I can’t tell is if this is a crumb tray issue or a GF floor issue. With small projects in the center, I am not sure it has any impact. But if we start using the whole bed, will this change the distance between the laser head and the material thus causing problems? Is the crumb tray “ground 0” or the bed of GF?
Any thoughts would be much appreciated!
As a sign off, I would like to say thanks to the GF team for making this great idea a reality! It was a long time to wait, but even after only 3 days of using it, worth the wait!! Simply amazing!!
