Why is it after all the work doing layout on the material in the unit I click save as and all it saves are the GF clip art images? Have wasted many hours on this and using bought SVG files I have had to re-do layout each time!
Welcome to the forum.
Have you tried exporting the file? When you close a dashboard file, it is automatically saved as it last appeared in the interface. There is no need to âsave asâ.
Iâm having the same problem. I create the design and export it, but when I upload the exported file, I get a message that says âThis design doesnât have any printable elements in it.â
Where are you clicking âsave asâ?
There is no âsave asâ option.
You can âexport designâ, under the three dot menu.
Any additional elements you have added are automatically saved in the design in your dashboard.
You cannot export catalog designs.
