I’ve noticed that the wood sheet options are more limited than before (i.e. poplar is gone and most of the ones that used to be available in larger sizes are no longer offered that way). Are there plans to restock these things? Are there alternative sources for sheets that are similarly flat (haven’t had the best luck from inventables with regard to flatness for instance)?
They were in the process of switching distribution companies recently so it’s possible that the low stock is still because of that - once they’re in stock they’ll re-appear in the store
For plywood a number of folks have been going to their local hardware stores and picking up Baltic Birch (BB ply), but you have to be careful because regular birch is not the same
For hardwoods, Amazon & eBay & Wood shops:
https://www.amazon.com/Butternut-Wood-Boards-Inches-Lumber/dp/B073SJ3813 (etc. - it’s Amazon after all)
https://www.ebay.com/sch/deer56hunter/m.html?_nkw=&_armrs=1&_ipg=&_from= (same etc. for eBay)
https://ocoochhardwoods.com/scroll-saw-lumber/
https://www.certainlywood.com
https://www.gvwp.net/
http://woodnshop.com/
https://rugbyabp.com/ ( just heard about this one today - not near me, but if it’s near you…)
I’m sure there are more, but that should get you started
thanks… thats quite helpful
We are out of stock of several types of Proofgrade Plywood and Hardwood. As soon as they’re available, we’ll add them back to the shop.
