Wooden kopis-style short sword
Cutpurse? I think you’re underselling me. I go by Assassin’s Kiss for a reason.
This is part of a three sword (so far) series that I’ve explored, a 26" LOA shortsword. I’m not going to get into process details, We’ve covered them a lot on the forum. Instead I’ll list a series of skills that you will need and you can search for them.
Things you’ll need to know:
  • Passthrough technique
  • Kerf Adjustment
  • Cutting and scoring techniques
Things it is good to know:
  • Wood staining
  • Wood finishing
  • Edge sanding/shaping techniques [search for my layered round boxes, I talk about it at length]
  • A functional knowledge of your Agrippa.
Materials:
  • 1/8" baltic birch blade
  • 1/8" wenge scales
  • 1/4" mahogany pins (dowels)
  • Wood glue
  • Wood stain (optional)
  • Wood finish (I used wipe on satin polyurethane
Tools:
  • A belt sander is really nice to have for shaping the blade. It will save you so much time.
  • Hand sanding block is basically a requirement
  • A bench vise or a clever clamping solution (Far harder to try to hold this while you do detail sanding. A vise really helps)
  • Clamps. Lots of clamps. You’ll glue a lot of parts together, but the blade is two layers of 1/8" ply thick, and that requires a lot of clamps to keep it together while the glue sets.
So, this is post 3, here’s your banana-scaled family portrait.
The two-hander is so huge, it’s hilarious :wink:
The series looks great!
What did you end up using for the dowels to hold the handle halves in place? More wenge bits?
Aha, right, forgot that. They’re mahogany. The scales are actually wenge/veneer/wenge, the veneer is an unknown species but I suspect a mahogany. I should take a side view.
That is actually more layers than I expected, but I am not surprised :slight_smile:
I really like how the wood grains display and you made a great selection no species to use.
:clap:
So it’s 2 layers of BB for the blade (which extends down the entire handle), 4 for the scales plus two thick-ish veneers. Total thickness… gets calipers… 0.76". I almost went with 2 more layers, but the person it’s for has smaller hands, so I figured this would work nicely.
Outfknstanding! Great work.
Oohh, really, really like this one. So awesome.
Can’t decide which is my favorite, these are all so awesome!
Wow. They look great! (Those bananas look pretty tasty too.)
Very 300ish… I like. :slight_smile:
#ForgedInLaser
So appealing to my inner 8 year old! Okay, let’s be real, the older me, too.
Inconceivable!
Dang. I love this so much. I keep coming back to look at it again. <3
Yeah, that handle…
Beautiful!
Are the blades multiple layers as well?
Yup!
Since it’s two layers of 1/8" baltic, that’s six layers of wood in total. You can see them pretty clearly in the pictures of the handle:
With the two handed sword it’s even more, three layers of 1/8" ply, which means 9 total layers of wood for that one. The blades are pretty strong with 2 layers at the short sword size, and might even be ok at longsword length,but I decided I would rather it be overkill than underkill if that’s a word.
Outside the box for you, but you are definitely on point! Excellent work!
Heh, not really. I’m a bit of a D&D geek, you see. If you dig around you can find more evidence: dice trays, dice towers, hero boxes, all that.
Swords were a natural next step… I have plans for more stuff like this too, more as it materializes.
You have shown a lot of exceptional work, we enjoy it all!
