Got great feedback for my last question. Now do I need to cover my leather with anything for engraving? Again, thanks in advance
Also best settings please…3-4 oz and 5-6 oz.
The term you’re looking for is masking, if you search for “leather masking” you’ll find a ton of threads.
You might also like this one, definitely check out #2 and #6, but I bet you’ll find them all useful:
Use the PG leather settings for engraves, they work beautifully and no testing required. For cuts I use the PG leather settings and then carefully see if the piece cut completely, if it didn’t shut the lid and run the cut a 2nd time (you can even speed it up a bit). Works every time.
I find that I end up cleaning and then conditioning the pieces no matter what so I mask pretty rarely, but it’s totally doable if you’re doing a cut and want an absolutely clean surface - don’t do it for an engrave, it just gets ugly
I just ran a test. No masking. Manual setting Engrave 1000 43 225. Came out clean as a whistle
I will check out the PG setting as well.
Thanks. This thing is just stinkin’ Rad!!
Interesting - no marring at all? No smoke residue?
None. Couldn’t be any cleaner. Stoked about it.
same here. I primarily use veg tan leather from Tandy and i almost never use masking. I just scrub the char and smoke residue off the edges and continue with my work. Just picked up some 7-8oz for a set of armor. Gotta get the new setting dialed in for this thicker stuff.
I’ll be the weird person and say that the settings for engraving leather may or may not be ideal for you. The
settings assume that you need to punch cleanly through a layer of masking and remove any masking residue for the engrave - it results in an engrave that may be deeper than you want. Think about your different grades of leather and the layers they correspond to -
If you’re using a nice full grain leather, the top surface of the leather is the expensive bit that you’re paying for. Personally, I try to preserve as much of that as I can unless I’m doing a project where I’m painting in the engraved area, and I frequently engrave without masking.
I don’t remember the exact settings I used for this project but in general it was both faster and lower power than the default engrave settings -
There is no “one true answer” - you may find different settings are a better fit for different projects (i.e. with light colored dyes, you may be able to use less power than something you’re intending to dye a darker hue.)
When in doubt, experiment, see what you like for your own works. There are plenty of different “right answers” for you to discover
