A wreathe I made a while ago. I cut this out from plywood, painted it white and glued it onto a background that was grey to make a nice dual color wreathe. You need to cut this out in two pieces and then glue together on the piece of wood (since the height it higher than the width of the glowforge).
Including the file for the whole item and the one I cut in two.
The other designs are designs I used for lazy susans.
I took some serif designs from elsewhere and edited them together to make the patterns, mostly. Plus a little editing here and there to add in the flamingo shapes. I used the warp tool and a few other things in illustrator to bend them and then copied them around a few times to join them together. After that I did another join to convert into a single object.
