I run an industrial laser for work and a very useful feature it has is easy scrap cut programs. I think this would be a great time saver to ad a simple cutoff program into the GF, anyone savvy enough to figure that out? I know I’m not (at least not yet…
Like this? it is what I use.
You can move it or scale it and shift and pick the rotate thingy and have it be vertical
That’s exactly what I mean! Except I can’t see a link
Wait is it just the purple line?
I believe so. He’s loaded up an SVG file there. All you need to do is right click on the purple line and choose Save As, or Save Image As.
It is a somewhat special line as it is only one way and will make a single pass and not two as is often the case. Put it where you want to cut and give it the settings to cut the materials you are using,
That’s great! Elegant and simple, thank you!
How is it “special”?
Lots of folks have trouble getting this as the tendency is to close the area making it two cuts,
In other words it’s actually a line and not a zero-height rectangle.
yes
