This just simply ROCKS, thank you
Ok, finally got around to posting the files on Thingiverseā¦link below:
Wow! Definitely some dedicated time in this one. Turned out fantastic! Glad you posted your re-mix on Thingiverse. Awesome!
I tried to open your 2nd file in Coreldraw and it didnāt work. How can I fix this? Or do you have it in another format?
Thank you! This is as generous of you as it is beautiful! (which is plenty!!)
I have seen this with stuff created in Inkscape and then loaded into Coreldraw more time that I can count. Since Inkscape is free I have it loaded as well as my Coreldraw. I open it in Inkscape then save it back out as a PDF and then Corel usually has no issues with it.
Sorry, not sure why itās coming in like that. All I have is the svgs and the Illustrator file, which Iām guessing doesnāt come into Corel. As @eflyguy said though, svgs should load fine in the GF interface, or most softwares.
Hmmā¦Iāve never used Inkscape, I was working with CAD dwgs, but then did some of my re-print modifications in Illustrator.
Yes, you can get Corel to open/import an .ai file. Done it myself when no other format was available.
If you still have the files I would love to get them. My boy loves Star Wars. Thank you.
Thanks for the link!
This is some amazing work! My son and I have several lego Models of the X-Wing and this will be an awesome addition to our model cabinet.
Friendly reminder that it is against forum rules to ask for files.
In this case, links to the files are provided in the original post.
Files are linked in the thread-I wound up uploading them to thingiverse. Enjoy!
Nevermind
Hello. This model looks incredible! I downloaded the files from Thingiverse and then imported them into Silhouette Studio to move things around because I only have 12"x12" pieces of BB. I was wondering, there are three different colors showing up. Black, I assume are cut lines, but Iām not sure what the red, yellow, and green lines are for. the red ones are the centers of the circles, and there are a lot of those. Based on the pictures, it looks like they are all supposed to be cut lines. Could someone clarify? Maybe those colors appeared only because I imported to Silhouette Studio?
