I bought a Glowforge Basic at the end of March, I use it quite regularly (1h to 2h per day) and since yesterday, the blue button turns yellow for a few seconds at the end of work. I do not know if this is related to heat and a cooling problem or if there is a bad connection between the print head and the tape (I removed and repositioned the print head to see if it was the case and apparently not because the yellow light comes back even at the end).
Can you help me? because I’m afraid to reuse it and damage it …
Make sure you don’t have some stuff right up against the right side of the machine, or that a loose piece of paper got sucked up on the bottom right–the air intake is the honeycomb holes on the underside of the machine, and early on I had similar yellow light at end of a job & it was because of a piece of paper got under the machine & was letting too much stuff get stacked up right next to the machine limiting the air flow INTO the machine for cooling.
yes, indeed a small piece of paper was under the Glowforge. with a drop in temperature and a little clean under the laser cut, it works normally … thanks for the advice
I’m sorry to hear that you ran into trouble with your Glowforge. It’s great to see that you’ve received some advice from our other community members. I also saw that you emailed us, and I’ve sent you some additional information there, so I’m going to close this thread.
