Did A longer Print Last night (Late) around 1:00am? came very close to finishing but at the end stopped moving, Fans stayed on and my Dashboard said “Cooling Alert” Let Machine cool down or contact support yada yada yada Its been of 16 hours now still same problem, Ive tried Everything on the forum I have seen as a fix. temp sensor? This is my second replacement Glowforge already
I have seen many times that the connection of ribbon to the printer head gets a little bit iffy and it reads as a temperature problem. Alternatively you can reboot the Glowforge and see if the problem repeats. I had the bright orange lamp of death a couple of days ago (though no “cooling alert”) and even lifting the lid did not shut off the fan. Rebooting the Glowforge did of course shut down everything and working today did not resurface the problem.
