For those of you who have the Glowforge, upon setting up did you have any problems? I can’t get started as soon as I turn it on the GF the button turns yellow. when I go to dashboard to print it says too hot to print. Meanhwile I haven’t even made it past the initial setup and wifi won’t connect
What is the temp in the room? Is the Glowforge on a table that allows for good air intake?
Temp is around 70-72. Yes its on a good table
I see that you’ve also emailed us about this issue and I’ve just sent a response to you there. To avoid duplicate communication, I’m going to close this thread and we will continue working with you over email.
