Last night I tried to run a job, got the temperature error, waited, waited, 4 hrs later never fixed. Today turn on machine multiple times and upon centering, yellow light, wont stop doing this.
I guess another laser is dead
If someone can look at the logs please
Check the white cable connections and clean the contacts under the head; also make sure the springy things there are springing back when pressed.
Hello @whickmant
I’m so sorry for the trouble. I’ve made a small change on our end. Could you give it another try and let me know if you’re still running into any issues?
whatever you did fixed it thank you. I am Curious how a bricked device can be revived remotely… what was tweaked to make it work again. Thanks!
Hello, @whickmant I just made a slight adjustment to the configuration of the Glowforge printer. I am happy we were able to get you up and running. I will go ahead and close this post. Thank you!
