Yellow Light on printer head not moving
Yellow light is on. The exhaust fan was running but that has stopped now. But the yellow light is on and it says that it in focusing mode but the printer head is not moving.
With the machine off, check that the white ribbon cable is securely clicked into place. Also, what is the temperature in the Glowforge room?
Do you hear any clicking from the print head when you power it on? It will be after the inline fan starts up.
Yes
Ironside
Then I would look at the room temp and make sure you are not having a coolant issue.
Thanks, I’ve been I touch with glowforge and they are swapping it out
Ironside
