Yeti Mug Life Preserver (Floaty)
Simple floatation device for a Yeti Mug. I use it in the pool
I used high density EVA foam. Specifically inexpensive flooring sheets cut-down to fit the GF.
I cut two of the patterns and used a hot glue gun to hold the pieces together.
Pattern:
Sorry for the late-in-the-summer posting. Perhaps someone in Australia will appreciate this… :slight_smile:
Settings for EVA foam:
Black lines (cut) - Speed 150 / Power 100 (needed to cut through the glossy layer on the foam)
Green line (engrave): Speed 1000 / Power 3 / 90 LPC / 1 pass (very light engraving)
Red Line (engrave) : Speed 1000 / Power 20 / 90 LPC / 1 pass (0.8mm engraving)
thats pretty cool! thanks for the share! what were your settings for the cut and engravings?
Any issues with the water and the hot glue?
Great minds…
Nope. The hot glue seems to hold very well in water.
I moved the post to the “Beyond the Manual” section and put the settings in the main post. :slight_smile:
OMG! I didn’t realize that this had already been done! Even the wording is similar… Should I take this posting down? Or perhaps I can just add to your posting…
Ha ha, no. Glad to see another project. Cheers!
Yours is an improvement! Insulated and probably more stable.
Thank you for posting this! Need to make some for our pool now! :smile:
Fun project!
