In an attempt to try and learn more about how to create my own designs using gradient 3D depth grayscale engraving, I used google image search and I found some images online to try out.
Keep in mind that these are fairly low resolution ‘web’ images to start with. I did increase the resolution to 300dpi (keeping the ‘print’ dimensions the same) and they are small. I’m sure that much higher quality source images would produce much higher quality results with much finer detail. Pretty sure these may be intended for CNC usage also. I was basically only trying to see what would happen printing these on the , so I could compare the results with the original pics as a learning/discovery exercise.
Also, they were all done using manual settings on the beta machine at a low lpi and a few varied speed settings just to again see what the results would be. I’m pleased with the results I got, and have a better understanding of what I need to do to create some of my own down the line.
If it’s not too much trouble, could you link to the images you used? I’d like to see how the file compares so I can better understand how the design part works, but I wasn’t able to find them googling at random I understand if you cant post them here directly, but even the right search terms would be helpful in tracking them down.
I actually love the slight pixilated look the low res images show off. @dan are you able to share what the bug is? My software developer brain is curious.
I wake up. Pre coffee I check the Glowforge forum like every normal person does then proceed to “WTH” is that crawling around on my my iPad… Thanks Jules…lol
Seeing the bobby pin for scale surprised me. I didn’t picture them that small. What kind of wood did you use? I also didn’t think the Glowforge could cut that deep in a single pass. That is beautiful work and thank you for sharing.
