Amen to both these.
When i returned to Australia after my first 3 years away i took a long look at the ‘extensive and exhaustive’ notes i made on my programs (on dot-matrix printouts lol)… they literally made no sense.
From spending hours a day coding to not being able to even read that code any more in just 3 years
Anyway, C# is my love now, that is good enough for me
I’ve never written any myself, but I worked with a guy whose first job was maintaining a pile of assembly code. There was a total of one comment in it: “This is the tricky part”.
I had one program I did that in - it was incredibly complex and so many moving parts with such a huge impact on the core structure of the system that I put one comment in “If you think you need to modify this, better to rewrite it from scratch.” It took me 3 months to write and every one of the architects and code reviewers agreed - never touch it
Some things are not worth fixing - better to start over.
I took advantage of un-implemented op-codes on the C64’s 6510 processor to do copy protection. Something like, if you do a jump on the border of a 1K block of code, it only uses one nybble of the jump address, instead of the whole byte. Things that would fool the assembler. Houdini-level misdirection! Such early white-hat black-hat stuff!
I wrote my share of 6502/65C02/65C816 assembly language back in high school. Did some SPARC assembly in college, and I have messed around a bit with x86 (yuck) and AVR more recently. But these days I stick with higher-level languages. Modern architectures aren’t worth writing assembly for unless you’re writing the code-generator for a compiler or if you’re writing some really low-level bits of an operating system.
PDP-8 assembler in high school and a bit in college. Some 8080/Z80 later. Which is why I am very careful about criticizing and instruction set as convoluted.
