Optical Alignment - possible for multiples?
Hello,
I have a query re this feature to the GF team. I seem to remember that one of the GF features was that we would not have to align things perfectly on the cutting bed since the GF is clever enough to align the laser with the shape of the object, no matter how it is positioned on the bed.
Questions:
  1. Is the above description of this feature correct?
  2. If not, how does it work?
  3. If so, can it be applied to multiple objects at the same time?
Here’s what we hope to achieve:
Design a pattern for engraving (no cutting) on a standard size strip of material (say 200x30mm). We can fit a bunch of these into the GF bed at a time. Would the optical alignment feature be able to recognize the shapes independently without us somehow trying to align them perfectly?
Thanks.
Remember the discussions but don’t think there was ever anything stating the GF will be able to do that. Dan has said if it’s not in the specs it doesn’t exist. Some talk about the request being in the hopper. As far as I can remember you can position and size the cut as you wish and I believe (not positive) you can even do it multiple times in a cut but it’s done manually. On the Pro the laser will do some automatic alignment with the previous cut on a pass-thru. That shows the possibility for future automatic positioning.
I was referring to the Optical Alignment feature from here: https://glowforge.com/?kid=zv0tJu
8. Optical Alignment
The dual cameras align the laser head with the frame, with your design,and with your material. Glowforge realigns with every cut and engrave, adjusting timing and position, so every print comes out perfectly.
At Makerfaire they were cutting out drawings. I asked if they could do two at once and they seemed pretty adamant that it could not be done. So we watched them cut my girlfriends first, then they went back and cut mine.
I’m not sure if this answers your question, but I think it’s what you were asking.
You seem to be referring to feature 1 on that page. I am referring to feature 8 as noted in my previous post.
This is a technical question about the actual ability of the machine. Would appreciate a response from GF on this.
You have to drag and drop the design on to the material in the UI for placement. It does not put it on there for you.
Dragging and dropping for precision engraving would not be very precise. So there’s object recognition for things like an iphone or macbook. The GF already has the ability to do that for a single object. The hardware can apparently already handle it. It’s a brilliant feature.
What we want to achieve is:
a. Multiple ‘object preset’ jobs;
b. ‘Custom object presets’.
Here’s how it might work:
  1. Place the first of the type of object on the bed;
  2. Drag and drop the design onto the object with due care as to accuracy (or perhaps just identify the engraving area on the object at this point);
  3. ‘Save’ that object as a preset;
  4. Do first engrave;
  5. Place another of the preset objects on the bed in a random way. GF cams recognise it and aligns the design accordingly. User confirms design. GF engraves (or cuts);
  6. Place a multiple number of the preset object on the bed in any orientation. GF cams recognise the preset shape (x n). GF engraves, realigning for each individual object;
  7. Go make coffee.
I agree, that would be awesome. It might be something they do in the future. Unfortunately there are a lot of things it cant do right now because the software isnt finished. Were still waiting to see the greyscale engraving, 3d engraving, and a list of other things that havent been completed yet.
Until then, and even if it is a feature, I have a feeling you will get a much more accurate engrave on something if you make a jig for those pieces to fit in, and then make a file to cut over the top of that jig with all the pieces laid out in it.
Sorry for the bad news but it’s a no on the object recognition. There were I believe other posts about templates you could use for specific objects, but the glowforge at least at initial shipping won’t be recognizing a random device just dropped in.
One of the few times it’s come up:
Really? So the GF cannot recognize the macbook or iphone anymore? That would be a real shame. It’s still on the website as a feature and of course in the promo video.
Does that mean feature 8. OPTICAL ALIGNMENT is no more? At all? I am confused…
I don’t think that’s referring to the same thing. I think the post you linked is referring to material recognition, and it makes sense that only the Proofgrade stuff would fall into that category due to the barcodes.
I think the OP is talking about auto-device recognition, like where the video shows engraving on a macbook. The question (I think) is whether an engrave on a device (say an iPhone) can be duplicated to a second device automatically, regardless of device orientation in the bed. And then, will this have to be done on subsequent prints? or can it be done on multiple devices on one print?
Based on the video, copying an engrave and pasting it onto the material is a manual function. Multiple copies of the engrave can be done at least on a single sheet of material (based on the promo video anyway - red and white invitations). As for doing this on a device… Even if the functionality was there, I would probably make a jig so that my device was in the same position every time, and I don’t think I would trust it for multiple devices at the same time.
I think that they could probably do multiple designs at once, but not multiple sheets of material. The Maker Faire demos were on small pieces of wood. If they had a bigger piece, then I don’t know why they wouldn’t be able to cut multiple designs at the same time. It’s just a matter of importing those steps and laying them out… which is all done manually.
Is that really true? It’s still in the primary sales literature…
I think everyone is getting a little bit confused about what exactly the GF is going to recognize about iphones and macs…
it’s going to set the focus at the correct height and power settings for engraving on those objects, it’s not necessarily going to align a pattern on it. We are still going to be responsible for aligning that optically.
Feature 8 promises more than that…
it’s part of the promo video
True. I wasn’t implying that it would align according to an object. Just recognize it visually. I was specifically responding to
Inside of a single print…yes. If you have a file that has both vector cut lines and engravings in the same file, some deep, some shallow, the software will calculate the relationships between the various parts of the design and reproduce them exactly. But the overall placement of that design on the material is still going to be our responsibility.
If you’re planning to buy a bunch of pre-cut wooden doodads for instance, and just engrave them, you will need to create a jig to hold them in place, because otherwise, they might shift, or not be placed square, and you might get engraving that wasn’t centered. The engraving would have to be positioned on the doodad by looking at how it turns out on the camera, and dragging it around manually. (Not sure if rotating the design is an option.)
If you wanted to cut them out and engrave them from a bigger piece of material though, you can rotate the design any way that makes it fit, and the machine will do what you want. But the initial file would contain both the cutting and engraving information at the beginning.
(Probably doing a terrible job of explaining that, but that’s how I understand it will work.)
I think the issue is that you are reading between the lines of the promo language. Yes the camera aligns the head with everything. It allows the GF to know where the head is precisely, So when you manually move your design over an image of the material things are aligned perfectly, with the frame, design and material. In essence it’s a positioning sensor. The GF also understands the z axis depth automatically. So technically the language is accurate. But it does not and never was advertised to understand the shape of random material so that the design can be automatically placed. And nothing has been advertised about multiple instances of a design other than manual control. That’s not saying that the capability isn’t possible with the existing H/W. Just that it’s not advertised as something we will get. It might be in the hopper.
For a potential use case, consider the following.
User X wants to make a snowflake for their classroom. They have a segment of a snowflake (1/6th of the design) that they created, but the snowflake is going to be a wooden one, with 6 removable pieces (one for each “arm” of the snowflake).
Ideally, the image/design/drawing would be duplicated on each segment.
User X could separate each piece and orient them the same way and duplicate the design on each, but Would it be possible to orient each portion of the snowflake radially and duplicate and rotate each copy of the design to print on each “arm” of the snowflake (for the possibility that the snowflake is one solid piece instead of 6 individual pieces). This would require that the design be rotated 360 degrees in order to print on each “arm” of the snowflake.
Not the best use case, but it was what came to mind first.
Correct me if I’m wrong, but this is my current understanding of how the Glowforge alignment works.
  • Macro camera takes an image of the bed.
  • You align your design with the material in the bed using this image.
  • Glowforge head is aligned using the macro camera and Glowforge logo fiducial on the back of the head.
  • Micro camera is used to insure cut accuracy and correct for height discrepancies in the material.
From my understanding, it can recognize macbooks & iphones as a material for settings, but not for alignment purposes.
I should note that I did asked about the Glowforge’s capability to recognizing fiducials at Maker Faire for the purposes of auto-aligning multiple parts. In your case, the fiducials would be the 4 corners of your material you put in. From what I was told, the hardware has the capability to recognize fiducials, but that it is not currently being used.
It would be awesome for auto-aligment to be added as a future feature. Hopper?
