Yeah that’s a good tip. I do sand a lot of projects if the parts are big and few enough. The real tricky cases are when you have lots of little parts, masking is key then… but removing the masking gets harder. I use a method I call the tape sandwich to get it done:
BTW @kryptonian you should come out of your fortress of solitude more often with good tips and projects
