Aaugh!
Doing an overlay and inlay silver bracelet of a peacock back about 1975ish there were 160 holes but also 160 stones cut to fit in each hole plus a bit of gold and it took several months but it was sold for $5000.
While I was working on it with the silver part about 80% done along comes this guy and tells me he has this gadget that could cut out the whole thing stones and all in a few minutes and how many hundred would I like.
Now I had not met the man before but I had seen his work that looked like an Inca wall but made of turquoise as a bracelet. To see one was jaw dropping, but to see several together, all with exactly the same “random” pattern the effect was quite different, and you could never “un-see” it, and his suggestion fell on my ears with a similar effect of someone telling me how much money I cold make selling my daughter to a brothel so I declined his offer.
In later years as part of the Ceramic League I watched the universe change as fine artistic hand made porcelain could not get $30 while literally across the highway similar sized mass produced very inferior Talc clay pots were selling well for $300 at Pottery Barn and where the piece individually made by a craftsman multiplied the value many times, now it was seen as inferior.
Things are less extreme now in either direction in part because the distinction is muddier. Where before I was fighting the accusation that lost wax casting was not “truly hand made” now the computerized tools we use does not make our work equivalent to Barbie Doll levels of mass production.
Aside from that rant, my original point was to haul out a jewiers saw just in those areas where the laser failed as the repair could be nearly invisible :slight_smile:
I am trying to work out how to do offset scores instead of engraving ( If any of you hotshot programmers can write an app for Inkscape?) but what looked good on paper was just a burnt mess (even over a millimeter 270 lpi is a lot of cuts) in wood so no I am avoiding engraves wherever possible, though that chrysanthemum as a coaster would be better off engraved,
You can never tell where the limits are if you never try and push past them.
Do you mean how to producing the cut/score lines, like something for the pattern above, from a centre line, drawn as your pattern ?
Or is it more complicated than that ?
Those are regular cut lines at 145-fullpower. Obviously too much power in the small areas and not enough power to make it through the bondo in the cheap plywood. What I find concerning is the time it takes for an engrave that travels back and forth for the whole width instead of a lot of parallel offsets as score lines. I do think it would probably have to be done in Inkscape or similar rather than the GFUI as I had hoped before actually seeing it.
As I understood it vector engraves were different than pixel artwork that only fancy raster to vector programs are capable of and even they cannot do everything.
Thats the worrsstt
