It’s great to see these experiments, both successes and failures. Thanks for putting the effort into do them and then reporting on them.
Or acrylic too ![]()
It’s not about avoiding horizontal lines in general, but about avoiding cross-hinge lines in living hinges. You can cut plenty of horizontal lines in other projects.
If you use a cross-hinge line in a living hinge, you’ve basically created another, extended, rigid area in your hinge, and it won’t bend properly. In the OP’s test, as the part was cut horizontally, cross-hinge also runs horizontally.
I’m not the OP, of course, but I have a laser and I’ve cut many living hinges. I do have a Glowforge on order, as well.
+1 to being able to make random boxes. I had done a couple projects as gifts for my SO’s parents (the christmas ornament was one), and we were leaving the next morning to fly out when I realized I didn’t have boxes for them. I was still at work and debating trying to find a late night arts and crafts store to get decent boxes when it hit me that I’m sitting 10 feet from a Glowforge and I can just make one. I whipped up these two boxes using your friendly local box generator and some imaginative shaving of tabs in illustrator in about 30 minutes, less time than it would have taken me to go to a store that was probably closed already anyways.
The best part: no glue required! (Yay for understanding kerf!) I made the lid piece a smidge smaller to allow it to be removed easily and just tied some plain string around them and presented them directly, and they can be used forever to store the gifts in.
Brilliant!!!
looks great.
Nice work @Kusmeroglu! I think I saw that design on Showforge I but didn’t know what it was going to turn into.
Is it safe to assume most veneers (since thin) can use a living hinge as well? I’m thinking of the walnut veneer wallet madebynick made back in January (speaking of which we never got the update on durability from him…)Today's Project: A walnut veneer card wallet
The veneer needs to be backed by something. My walnut veneer watchband’s been holding up great!
A lot of veneers come backed, which is nice for initial work. But do they even require a living hinge? (across the grain, I guess)
I warned you about small pieces and padauk!!
“Fragile” is not Italian. hehe
Are you still liking it?
Exactly - whenever something doesn’t work, you haven’t failed, you’ve just learned how not to do what you want.
Yep! Like the man said, “There’s no such thing as failure, only more data…”
Awesome!!!
Thanks for all your efforts and your very creative mind😄
