Yes @eflyguy , I cut the main escapement gear, the pendulum and one of the minor gears, all from 1/4" clear acrylic. (Actually I repurposed an large office rug protector sheet which is all scratched from years of chair bearings rolling on it, so I turned it into âfrostedâ acrylic by passing a 800 grit sander).
The largest acrylic parts did indeed warp a little, enough to be noticeable when revolving around an axle, but I corrected the distortion with careful application of a heat gun and a some patience. However unlike the MDF conterparts, after being straightened, the acrylic gears have remained true and unaffected by ambient heat and humidity.
I have yet to experiment with plywood gears.
Also all shafts are polished brass and tubes, with bearings only for the pendulum.
Here is a short video of the hybrid MDF/Acrylic design.
