The Unite tool, is that the same as Object, Group?
Guess I"ve got my work page set up different. I donāt see that menu, but I will search for it. Those other tabs are located at the top of my screen (Align, Transform, etc). Thank you for the help.
Go to Window > Pathfinder and make sure that is checked. It should pop up on the right.
I did it! Thanks so much! You should totally get compensated for all your work and advice on here!
Chuckle! For this kind of designing, you will probably always want to have a few palettes turned onā¦Layers, Pathfinder, Align and Transform. (Also Color, but that one is probably already open.)
I agree. Although, I know I may be trying to pull the cart before the horse just a little⦠
I do sincerely appreciate your help. I have learned SO much already today. Iām so excited!
Have fun!
