Cow hide
I echo the PG settings - but realize skin (of any sort) will almost never cut cleanly with a single stroke. The testing method is helpful, but I find using the PG, and then running any cuts a 2nd time at a high speed will catch the thin bits that are left behind from the first one. You should definitely use something to hold your material down (I use the honeycomb hold down pins)
Finish your cut, then carefully pull at the pieces, if they don’t release fully, close the lid and run just the cut again (set anything else to Ignore). Do not re-focus, or move your design, just close, up the speed, and click Print. Get used to doing this on all jobs and you’ll never waste material from cut failures again.
