Just draw a line or, if the design has corners where curves or corners might matter, a small square or circle. Upload several times into the same file (you can’t copy and paste as that would use the same settings) then use manual settings to try different power and speeds. Go to extremes, figure out what works or is close, then change settings between those narrower ranges until you find settings that are acceptable.
