Interesting. When I get home tonight I’ll post some pics of the edge of 1/4 poplar and 1/8 inch birch ply I cut for my Teardrop trailer. The edges were brown, not black. Perhaps the sap in the poplar protects when it’s cutting. There was a lot of sticky residue on the outside edges once cut. Nothing a sander won’t take off however!
Oh and if you’re getting into baltic, it can be finicky stuff. This trick can save you some headaches where it doesn’t cut consistently:
https://community.glowforge.com/t/trick-for-inspecting-plywood/15168the only thing that can get you is the glue they use (and sometimes the filler). I’ve got a “bad” piece that cuts 99 percent of the pattern but I end up just snapping out the last little section and sanding smooth. No biggie, just something to watch for.
I didn’t see anybody mention how smokey/sooty the BB plywood can be too. I use it for a lot of prototyping because it’s cheap to burn I end up cleaning a little more often too.
Try the trick I mention above next time, I bet your 99% is more about internal inconsistency in the plies than the glue.
I normally do. This was stuck in the pile and didn’t see it.
It has provided a lot of amusement though, just nothing usable for anything other than prototyping
I’ve cut a lot of 1/8" BB. Around 200-225/Full works well. BB is real smokey, so you have to remember to clean your optics (including your lid camera) a little more often.
Remember when using “full” you have to specify pro or basic. The numbers 1-100 translate between models but Full is a different ballgame. I do 220/full/1x on a pro and it works really well with minimal flashback.
Here’s a puzzle piece that I just cut and pulled out… 1/4" baltic birch - the tail is about the thickness of a dime.
Where do you buy the plywood? I’m having trouble finding 1/8" wood.
Where do you live? There are lots of places to get it but cost can vary widely. If you’re in the US, michaels has it, as do wal mart and woodcraft and even ace hardware sometimes.
There are cheaper options though, you can order it on amazon or a handful of other sites, and that’s better on cost.
By far the cheapest option is generally to find a local supplier and buy large sheets. Most lumber suppliers will also cut the sheets down to size for a small fee (or even sometimes free). Try searching for “hardwood supply” or “lumber supply” and so on in your area, google maps is your friend here.
My supplier sells 5’x5’ sheets for $15, cutting it down is officially supposed to cost $3 more but they haven’t charged me for it yet. 5x5 turns into 15 full size 12x20” pieces (disregarding kerf on their saw).
I haven’t purchased anything from here but balticbirchply.com (wood workers resource ) seems to have reasonable prices and I’ve heard only good things.
Whatever thats worth.
I’m located in Philadelphia. I’ll have to check the local Michaels. I googled local lumber suppliers and there’s a few in my area. Looks like more of what I’m looking for. Thanks for all of the info. It’s greatly appreciated.
If you aren’t adverse to a drive to get good prices on raw lumber, check out Hicksville Planing Mill in Hicksville, MD. Far and away the best prices I’ve seen. I just wish that I didn’t live over 1.5 hours away from it.
EDIT: I see that Philidelphia is about 3 hours away from it…sooo maybe not.
I’m a true city folk and without an automobile so MD is definitely not range friendly for me. Thanks for the suggestion nonetheless.
How are you cutting 1/4. For the love Of god, I cant get it cut thru. I don’t know what I’m doing wrong.
This was awesome information and worked perfectly for me! Thank you so much for sharing!
