Just stand under the text right click and save as they are all there!
Looks like this on my monitor:
I didn’t know that nice tip! Thanks
Well specially for you then a zip file with all the files!
I am in awe. This is exactly the type of box I wanted to create for my great niece to put her mementos of her momma in. I love it. You are so talented. Thank you so much for sharing.
Thanks for the change, it now shows up on my monitor!
I do the same thing! I learned that lesson quite a few years ago. This is beautiful and I’m amazed and grateful for your sharing. Thank you. Hmmm the t-shirt seems unworthy to go in there…maybe I should make this for my mom who would really appreciate the beauty.
I was wondering what other kind of wood I could use other than the Trotec Plywood? Thank you.
I would guess any plywood the same thickness would be fine.
Wow. That is just lovely!
The Trotec walnut that i got was is slightly thinner then the Glowforce medium walnut plywood i have. but it is almost the same you may need some sandpaper to get a snug fit.
It is made it for 3.2 mm walnut. But all the wood varies a bit so you probably be good Glowforce medium walnut plywood. You can always test a few joined to see how it fits for you!
Thank you so much. That helps a lot.
Very nice! Thank you for the share.
