Here is my first glock mag test. Tried to fill it with paint as well. I think I prefer unfilled
I did some more testing as well. Turned out way better this time. Also tried coloring it in and prefer it not colored
The pmag colour change is way better. I wish the glock mags did that as well.
Has anyone done a lower yet? I’m eager to see how well he gets through the anodizing.
I haven’t seen anyone try one yet but I will be giving it a go maybe next week.
You just gave me some ideas for my range mags… Did you have to remove the crumb tray? I just got my Glowforge yesterday and haven’t done much with it yet.
Yep, anything except a 1911 mag is going to require you to take out the crumb tray sadly
Damn, thanks for letting me know! Should I place the glock mag in solo or have it rest on something. Going to do my single stack G43 mags first to test it out.
Removing the tray is simple (you just need to find legos or whatever to prop it up on (pieces of
scrap stacked work great). If you are going to lay the mag directly on the honeycomb make sure it lays exactly flat (like if there is a lip at the bottom of the mag for instance) then you have a variable focus situation, which needs to be avoided.
For glock mags my setup is a steel parallel (1/2 i think), then 1" diameter magnets then the glock mag. That gets it into the glowforge range and keeps it planted
Looks like the only place you can prop it up to keep it perpendicular to the laser is between the two red arrows? Beware the bumpout at the bottom could knock it off level which would change the focus.
Thanks so much for the advice! I’ll try it out over the weekend and post my results. Been so busy here at the school, I haven’t had a chance to play with the machine
Any updates on this? I tried myself on engraving my mag and felt like it did not really come out god. To see it you have to view from an angle but dead on it kinda blends in.
pretty much how it goes; even when I do painted metal mags it only shows at a certain angle; it’s a very subtle thing. You might want to do it with masking on and spraypaint/fill it afterwards
If I get some time I have a glock frame I’m going to play with and try stippling.
I like the way it blends in until you catch it at the right angle. Here’s my attempt using settings and advice from this thread:
Did you adjust your power/speed settings on this one? I’m doing some pmag tests today and really like how yours turned out. Thanks!
Engrave settings for pmags were s-1000,p-50%,340lpi
Thank you sir.
