Exhaust Purifying aka HOA strikes again
I have this : https://www.amazon.com/BlueDri-Scrubber-Filtration-Negative-Airbourne/dp/B01JHI66VC?pldnSite=1
That while expensive is perhaps 20% of what you were looking at. It has a 10-inch intake and a six inch exhaust which is a problem of connection I have not properly solved. Instead I just let it run as the main exhaust fan is iffy and the helper fan only helps some so I do get a lot of smoke coming from the Glowforge if what I am cutting is very smoky.
The room does get somewhat smoky as a result but quickly clears as the ( I call it the blue whale as it is big, blue, and a filter-feeder) can move 500-CFM when on full . It is somewhat loud but a low white noise, less so than the shop vac that is also whiney,
They sell 10-inch to 4-inch adapters but they take up almost as much room as the Whale, so I have not yet gone that way but your situation may be different. Even if at some future time I should get the Glowforge filter I ordered I will still use the Blue whale as it also clears out all the smells and dust that sanding and other operations create in abundance.
