I will attempt to address some issues experienced with the original. Sometimes the gumballs get into a position where they won’t fall into the holes, so I am adding an “agitator” to keep the balls moving until they fall in.
If I can get this working, I will try to create detailed instructions and submit it to the catalog.
Good to know! I will probably try out a variety of them.
I also noticed that these gumballs are about the size of the marbles for my marble machine, so maybe it could eventually evolve into a gumball-run dispenser…
I love to use it to virtually assemble my projects before I cut them. I found a point where my ramp was digging into the catch at the bottom. So I adjusted the shape at the bottom; then when I did cut it, it was perfect and fit nicely!
You could drop one gumball every hour as long as the clock was wound so if you stay working at the desk the gumballs come every hour but not if you do not wind the clock and that only lasts for 10 minutes. With the need to pay attention and be there a lot of homework could get done in between…
