Image of the outlines → right click-> save as-> .svg
If you don’t have the option for .svg, use a browser other than Edge.
That is beautiful Thank you for sharing
Where do I find the image to right click on?
Thank you!!!
I love this!!! I have cut it out for my granddaughters. Do you have directions for assembly???
Thanks so very much for your share AND your help!!!
Janet
Not specifically really. You can tell the four top pieces as they are not as tall as the bottom. The circles go to the back, you can see how it needs to fit when you put it together ( there are two pieces of sides with an arched cut on them (bottom pieces). The top ‘tabbed’ piece is the back of the bottom of the box. Put the top and bottom of the box together. Keep the circles that are cut out, once you put it in place, you glue the circle to the tab in the top right design- this allows it to open and close. I think once you fit it together you can see how it fits. The left 3 and bottom right are the ‘tic tac toe’ pieces that just slide together to fit.
