Has anyone tried weeding using high-tack transfer tape?
OK so I had a project with a lot of etchings on the surface of larger pieces. This meant that the masking was cut into tons of pieces. The plastic razor blade worked amazingly well, I started with tape and not only got spotty results but was also using a ton of tape in the process. Plastic razor made very quick work of it.
Good call, @jules.
