How to cut monograms
And one other thing: if you do things with text where the letters overlap a little ( this often happens with script fonts), after converting the text to outlines you will need to do a Pathfunder…Unite (Illustrator) operation on the selected text. Otherwise the area of overlap will not engrave the way you expect.
