Just a warning. Vinegaroon sounds like it’s the same as the wood stain “liquid nightmare”. The guy who named it that put the vinegar and steel wool in a jar and sealed it with a cap. After a couple days the solution built up pressure and blew up all over the shop. It is now suggested if you make Liquid Nightmare aka vinegaroon do not seal the jar tight shut.
As far as results–I’ve had very successful etchings using chrome & oil tanned leathers–ventilation is key. And many of those have been on garment grade, or even upholstry grade hides. (And less than a few oz, or about 1/8" thick, it’s rarely veg tanned).
Also it’s rare to find “natural” (undyed) chrome tanned or oil tanned leather, so if it’s natural, odds are it’s veg tanned.
And if water absorbs into the hide, it’s more likely veg tanned than chrome or oil tanned. The latter have greater water resistance, and water will just roll off. But veg tanned will actually absorb the water (at least w/ the pieces I’ve had–many not true in all cases). A great feature for tooling and forming/molding the leather–not something you can do with chrome or oil tanned leathers.
Don’t know about the float test itself in boiling water–I’m sure that does happen initially. Might have to try that out of curiousity.
But natural, undyed veg tanned leather will absorb water–if you wash, or soak it in warm water, it will absorb it.
And all my etched leathers I run under a light flow of tap water & clean the etched areas w/ soft tooth brush, as a lot more soot is left compared to other materials. And just doing that, I know the veg tan/undyed gets soaked and needs time to dry (and thus great benefit when trying to form or mold a shape).
I know because I’m from Texas and I pay very close attention to anything that looks that much like a scorpion.
Now that we’ve gotten that out of the way, the vinegar / steel wool stuff that people for some reason have given the same name to is freaking awesome. I love it. Makes a beautiful dark gray / black color on leather, and you can also slop it on wood to make it look like you dug it out of the scrap pile on the back 40 instead of just pulling it out of the sale bin at the hobby store. I paint it on with one of those cheap foam hobby brushes.
It’s smelly and looks disgusting, but it’s my absolute favorite leather treatment.
The water float test is also how you tell which eggs not to eat, when you find a nest one of the hens has managed to keep hidden from you. (floating = bad)
I’m correct. Boiling water curls chrome tanned and does not affect veggie. Both will soak up water at various rates I’ve time but we’re talking a quick test here not minutes or hours of study.
Just as an aside, the issue with chrome-tanned leather isn’t that there’s any risk to the machine, it’s the concern that you may be creating hexavalent chromium during the laser process.
Hexavalent chromium is very very good at giving you cancer and manufacturers who produce it have all kinds of exciting monitoring regimes they have to undergo.
Beware, and take care where you’re venting when you use chrome-tanned leather. I’d make sure there aren’t any kids anywhere your exhaust stream, for example, and I’d also personally make sure my fumes aren’t anywhere near my garden.
…however, I’m paranoid since hex chrome is a problem for welders, so I’ve had the warnings beaten into me.
In the absence of oxygen acetic acid will react with iron to make ferrous acetate plus hydrogen gas.
Fe + 2 CH3C00H → Fe+2 + 2 CH3C00- + H2
Ferrous ion bind to tannic acid to make a dark brown soluble pigment.
Ferrous salts have a slight blue-green color and rapidly oxidize to create ferric ion:
Fe+2
which has low solubility at neutral or high pH, but the
acetic acid takes care of that. Ferric ion reacts with tannins to form a dark insoluble pigment.
