After seeing so many people questioning how to both vent and use the filter (as well as whether the filter will be up to the task on its own), the ideal solution would be for the 'Forge and filter to be engineered in a way that the dirty air from the 'Forge can either be sent straight out the vent, or be directed down into and through the filter and then back up and out the existing vent outlet on the back of the 'Forge. I would envision a swappable unit that goes into the left end of the 'Forge to enable the down and back up path instead of the straight out of the base unit, with a lever on the filter that could be used to move baffles in that filter-enabled module and toggle the filter power so the people could chose between vent or filter with the throw of a lever, and still have the outflow go through their existing vent and out of the building.
I have have an idea how this vent reconfiguration thing could work, but it doesnât yet exist outside my head. If it is evident that I should be mocking it up more formally, I will, but I am also not an engineer by trade, so it wouldnât be perfect.
The Glowforge has a connector to the air filter, which exhausts through many openings into the surrounding room. If you want to vent, donât use the filter. If you use the filter, you canât vent. The Glowforge plastics are final (the filter plastics are not) so that arrangement is not likely to change.
Aside from disappointments in features that canât be implemented, it is good to hear that the case design is finalized. Every little tidbit of info that moves the schedule closer to shipping is good to hear (or read).
Sorry, @dan, my suggestion for venting even with the filter was not aimed at the current iteration, it was more in the spirit of possible improvements for 2.0 or beyond.
You did mention that the filter plastic isnât finalized yet though, so if it is possible to tweak the filter so that all the outflow exits from one place, that will at least make it easier for those of us the need to implement something more for whatever reason can do so more easily!
Hopper Request: Flipping Accuracy with two seperate patterns?
I have read about the feature that automatically lines up cuts when needing to flip something over. wondering if a different design pattern can be used on the flip side.
Example: if I had a design for a wooden spoon that was cut out with engraving a concave on one side, could I theoretically engrave the convex on the opposite side so that the profile would match up and effectively produce the 3D relief on both sides?
In the embedded interview Dan address this feature in terms of finding corners on one side and then you get the go ahead to flip longitudinally it orients correctly. This is a feature and I have no doubts that it will be awesome to create as you describe.
Something else I was thinking last night that would be a good idea (and very well may already be in the works) is auto aligning for repeated cuts or engraving. (I know they already have auto re-align for passthrough) For example⌠Engraving usbs. Have it so that the GF will see each one on the bed and repeat the same engraving on each one, no matter where it is on the bed or orientation (to help with consistency in jobs)
Just a thought.
Thatâs basically how the macbook/iphone engraving will work. Obviously doable, but theyâd need to expand on the concept for generic objects. Good idea.
Some detailed example uses would be helpful so we can understand what the feature would ideally do for you.
I guess the big thing (for me at least) would be say⌠You print out a sheet of⌠Say a logo⌠And there are multiple instances of the logo on the paper. Instead of manually dragging the path onto each logo to cut them out you would just do one and tell GF to look for others.
Other uses for me personally would be for engraving USBs and their boxes. Itâs going to be a pain to try and align them over and over and then not have the same consistency as you would with this theoretical feature.
I have thought of jury-rigging some work arounds⌠but this could greatly help!
I could be missing something here, but that seems to be what happened in the promo video when the airplane was reproduced in iterations. Although on second thought, I have no idea how consistent the alignment was for each of those iterations. Your USBs would obviously need to be placed pretty precisely.
I think Iâd cut a tray out that would align the USBs and then use that. A bit more work to drop them all in the holes but once done should be good enough. I believe this was suggested elsewhere for multiple align every time problems.
Sorry, I should have been more clear. In the video it just cuts and engraves multiple iterations from a blank sheet. So it doesnât really matter in terms of alignment. This suggested feature would identify existing objects and then engrave on the same place on each item.
@ihermit2 yeah, thatâs the workaround I was thinking of.
Are you sure? I just watch the clip again a couple of times, on the âWatch how it worksâ video on the main glowforge page. At 1:27 there is a two-second shot of the woman using an ipad to move the airplane onto what i think is a lid-camera shot from the 'forge, and it shows six separate pieces on the honeycomb.
Of course⌠that could also be a non-functional mockup app just for the video.
Oh, maybe youâre right!! Hmmm⌠Weâll see I guess.
Well, we donât know if she positioned an airplane on every part in the tray.
And since the thing she was doing was a full cut-out, aligning to any slight skew doesnât matter much. Engraving on an existing object and wanting every engrave centered and equidistant to the end would be more what the question at hand involves.
@jacobturner you are right. Ha, and now that I think about it⌠she is an actress. They are on set. The cuts and laser shots could have been done anywhere previously.
Behold, the magic word of Hollywood! (says the guy that works in Hollywood)
I seem to have missed that this was also being discussed over here. We do know that alignment will be at least partly based on the corners of the material. The question is whether it can precisely align to multiple objects at once, and then if/once it can do that, can the alignment be specified for the batch (ie center all, or align copies to left edge of bottom +.5cm padding) or individually (ie drag each copy over material in bed, align each separate instance using a center to material function, or dialogue box with something like align to: [select edge] +/- [#] of [units]
@JeremyNielsen 's USB use case may not be using rectangular-shaped USB devices. The could be circular or complex shapes too. Wonder how that would work with corner-alignment.
Another thing I would love to see is an easy way to do two sided engraving that would handle the alignment when you flip it over.
