saw or seen?
Saw is past tense, seen is a part participle and is usually half of a compound verb, so youâd need another verb to go with it.
âhad seenâ would work, and is arguably better because of the âeeâ sound. IDK, sounds weird when I say it
(I bet english as a second language is a nightmare)
You know what I think you might be right. Itâs a nightmare for first language too
This reminds me of âBegs the questionâ. NO it doesnât! You canât beg a question. You can beg FOR a question, so say that âBegs for the questionâ.
Begging the question is a circular fallacy thatâs not correct.
Wait till you get a load of buffaloâŚ
I had this formula posted on my computer for the longest time . It works-although you end up with another size, but most of the time thatâs okay too!
I had to look this up! Wow, I had to read really slow for it to sink in!
Thatâs not what âbegs the questionâ means. Traditionally it meant that the speaker was assuming the conclusion but has more recently come to mean âsuggests the questionâ.
You are correct though that in the traditional sense that itâs a circular fallacy. Thatâs no longer the case as the language & usage has evolved.
Bookmarking this handy formula! Thanks!
this is an excellent fusion360 tutorial that geared towards laser cutting with tabs / slots:
it uses parametric dimensions so if in the future you change the material thickness it will adjust the slots for you. very well done too.
itâs easy to trace over the image you posted above:
between these 2 videos I learned 95% of what I use fusion360 for lasercutting.
Perfect!
This is my personal obscure pet peeve that I thought nobody cared about but me. Thank you!! Iâve yelled âItâs not begging the question, itâs raising the question!â way too many times (=more than never).
Love it!
Yes - but one of my favorite sports talk show guys, Mike Greenberg of ESPN, says it ALL THE TIME. And it drives me nutsâŚ
ââŚwhich is not correct.â
Well, ok. BUT - Iâve always heard NOT to use which. Use that instead.
LolâŚâŚdear googleâŚ.
SoâŚ.I didnât like the restrictive and itchy woolen slacks but MW said I had to wear them for this researchâŚ
It is true that that is rarely found today used in nonrestrictive clauses (although poets still use it thusly), but which seems to have a fair degree of flexibility to it, and can perform very nicely in restrictive clauses, nonrestrictive clauses, and in annoying people who feel that it should never be found outside of a nonrestrictive clause. Here is what our own usage guide, the Merriam-Webster Dictionary of English Usage , has to say on the matter:
We conclude that at the end of the 20th century, the usage of which and that âat least in proseâhas pretty much settled down. You can use either which or that to introduce a restrictive clauseâthe grounds for your choice should be stylisticâand which to introduce a nonrestrictive clause.
SoâŚ.anyoneâs call?
This has turned into a grammar nerd thread, and Iâm here for it.
Iâm glad I could pique everyoneâs interests. My apologies to the OP.
