KJP Hardwoods
Your best bet is going to be to do a pretty standard material test that described the number six on this list:
It’s quick and easy, in about five minutes you’ll have the perfect answer for your specific material. Then if you have a minute you can tell us what’s best — since it’s a fairly niche material any research that you do may help everybody else that comes later.
Once you set up the material test, you can use it over and over for any new material that comes your way, making this process even faster. You’ll find that it is almost always quicker and more accurate to test than it is to ask and wait for a response, it’s a great technique to know.
