They are not traditional bolts and nuts, they are actually plumbing hardware, and the “nut” is some type of cap.
I don’t want to do anything permanent, because I may have to move them elsewhere. I may have to figure out how to drill a hole in the cap so I can use some sort of cotter-pin.
best I can think of is to double nut it unless its a pipe cap then in that case a cross drill and pin and a dab of lube on the face that touches the gear
Safe to assume not cut on a laser?(unless really big bed). Very kewl to have in the house - what a conversation piece and the gears are so ornate (as opposed to simple toothed circles). Nice job
One of the things that’s hard to wrap one’s brain around (at least for me) is the notion that it’s possible to cut mating pieces out with a laser, allowing for kerf, and have them just. fit. If I cut something by hand, I’m lucky to get within 1mm (at least on the initial pass). If I 3D-print something, maybe a quarter of that (allowing for surface texture, rounding of corners and warpage). I’m looking forward to being able to design stuff where multiple parts fit reliably.
Same here - after struggling with this K40, seems like kerf is always too wide…(Granted it’s user error most likely, which is why I want the GF;s user-friendly interface so badly)
