HI friends-- a little late to the table, but here’s a recipe I’ve been “focusing” on this year:
“Not Neva’s Rum Balls”
My mom made rum balls every December when I was growing up in the '60s. Haven’t had once since, but this year I was feeling nostalgic. Not a big fan of rum or black walnuts, so I decided to doctor this recipe…
Ingredients
1 cup pecans
8 ounces vanilla wafers, enough to make 2 cups
1/2 cup unsweetened Dutch-processed cocoa, divided
1 cup confectioners’ sugar, divided
1/4 cup light corn syrup
1/4 cup bourbon
Directions
Preheat oven to 325 degrees F.
Spread the pecans on a cookie sheet, and place in the oven for 3 minutes. Toss the nuts and bake for another 3 minutes. You’ll know they’re done when they give off their fragrant aroma, don’t overbake or let them char!
Use a food processor to chop the vanilla wafers into crumbs and set aside. Process the toasted pecans until finely chopped.
In a medium bowl, mix together the crumb-pecan mixture, 1/4 cup of the cocoa, and 1/4 cup of the confectioners’ sugar. Add the corn syrup and bourbon. Mix thoroughly.
The mixture will seem too dry to form into balls, but resist the temptation to add more liquid. Seriously.
Form the crumb mixture into 3/4-inch balls and roll them between your palms, compressing them to form a tight ball. A #50 cookie scoop is just about perfect for portion control.
Place them on a baking sheet to rest until the outer layer is almost dry. The time will depend on your local humidity. Here in Colorado it take about an hour.
Combine the remaining confectioner’s sugar and cocoa and sift over the bourbon balls. If the mix “melts” onto the surface, they are still too wet. Wait a bit and try again.
Store in an air-tight container for up to 5 days. This is a swag guess — none of the batches to-date have lasted that long! By the way, the alcohol evaporates fairly quickly, so they should be kid-safe.
