Wow! And that looks exactly like the guillotine cutter I used to use. Loved that thing.
Nice restoration! Smooth and quiet.
Iāll bet you made louder noises moving it! At least you had gravity on your side, more controlling that effect than lifting!
They are showing that product at .063 inchesā¦which is 1.6mm. The kf152 from boxcarā¦is 1.52 mm ⦠at .1mm off it looks like a very nice starting point. Iām doing the same thing, though I was going to start out with mdf or Lino and build up. Think Iāll purchase some of this sand give it a whirl
I purchased this product and have been doing some experiments today. I made some āplatesā in the acetal and some proof grade mapleā¦I have also ordered some exposed polymer but itās currently lost in fedex-land ugh.
I engraved the acetal with S:200 P:40 LPI: 270 and F:.06 - the result was really promisingā¦thinking I could make a deeper impression with a stronger relief I made another with the power up to 45ā¦also a great resultā¦upping the power further just resulted in too much melt on the base. Both of the successful cuts warped a bit. Then I did another with the proof grade maple.
The acetal was fixed to the boxcar base with carpet tape to account for the warpā¦both cuts gave very nice resultsā¦the lower power setting was better in fact and warped less. The carpet tape is really too strong but I fixed that by sticking to my hand a bunch of times making it sticky enough to grip but not too hard to get off again.
The proof grade maple was a great cut but I would reduce the power considerablyā¦the depth was really not necessary for letterpress and the scorched wood was tough to get clean. The cut was good but the pre-finished product didnāt grab the ink (rubber-based) as well as the acetal - unfinished wood would be better of course. The proof grade maple ply + 3/4 ā Medford = 4 layers of painters tap ended up tho-high
And another test - this was also done with acetal - which really picks up the ink well -ā¦this example was one where the settings were
S:200 P:45 LPI:270 F:.06. - what this is meant to show is that with the higher temperature it also impacted the graphic with the vapourized material - kerf-like. The initials were bolder on screen. I am going to try with a power less than 40 - this may result in less warping - the relief is plenty and the plate may be closer to the original on-screen graphic.
Also result is showing different papers
This done with proof grade settings was a wonderful result - better after a light sand on 600 sandpaper - took a nail file to the outside of the square as well - the woodās grain when burned can impact the graphic.
Once again - proofgrade maple ply + 3/4āmdf + 4 layers painter tape = type high
Looks like some great results, especially your architectural accent.
Lastly - the image shows two pieces of my Garamond font - itās 18pt Garamond light - and the graphic with the font very close to that size. Result was gorgeous but unfortunately the āyā collapsed in the press and the bottom points on the monogram donāt quite meet because it basically got burned away . Using prrofgrade settings is over like for this application. Iālove try it again with settings for a less deep engrave⦠at least before I resort to grayscale shoulders
Too bad - it was looking so promising.
Very cool experiments! I fiddled around with some letterpress-like printing in December for my Christmas cards, using Draftboard, and found that I lost bits by the time I had printed about 50 of them.
I previously used my 3D printer to make blocksā¦Iām going to do the capital g in a diamond one and compare the result - so far Iām thinking the laser is giving much crisper results⦠certainly Iām getting very nice detail - finer than Iāve been able to get with the 3D printer.
Looks good! I think a little green gremlin photo-bombed that last pic thoughā¦
